Am I missing something?
Al Navas
Re:
Post by Al Navas »
Rick Palechuk wrote:I see :?: what you mean Al. It's saved as an assembly (esa) so it should work.
Rick,
I added the bold formatting, for emphasis.
I believe that the bulletin board software does not recognize the suffix *.esa properly. As a result, it may have to be fixed on Thermwood's end. Either that, or my browser is having problems... I am using IE7.
Al
http://sandal-woodsblog.com
I think I got it now Al.
CC2.esj
(731 Bytes) Downloaded 534 times
Al Navas
Post by Al Navas »
ONLY 731 bytes???
I think something is wrong, Rick. I would expect the job file to be quite a bit larger. But, I am a newbie... :wink: I can't figure out what is going on, and why the files downloaded don't reflect what may have been uploaded.
It could be that I am not loading the job properly. I will keep trying, though.
Al
Ok Al, I guess I should have zipped it first (duh)
corner cab.zip
(242.37 KiB) Downloaded 518 times
Al Navas
Post by Al Navas »
Thanks, Rick!
I truly thought I was having strange things starting to happen with this new laptop. I appreciate you taking the time to do this, as I learned a neat trick.
Al
Hey not a problem Al! That's what the forum is all about.
