Myster Partition
Re: Myster Partition
I can't get it back to normal no matter what.
At least it is an easy cabinet to recreate from scratch.
DarrelMWood
Post by DarrelMWood »
Attached is a custom layout....if you take the upper assembly into cabinet editor, and go into the partition editor, you can see what it looked like before I took out the partition. Hopefully that will give you more info as to what caused it to happen----this is the first point at which I realized something was odd. I had removed a lot of the trims and moldings (display objects and cubes) to study/tweak the details and joinery.
I wasn't planning on using this cabinet/assembly/custom layout for anything more----I brought it up in case there was some underlying program bug that needed to be discovered.
vanderkuyl7.esj
this has the cabinet prior to the center partition being removed.
(2.13 MiB) Downloaded 345 times
