Rick,
Thanks for your answer.
I will try do to that. Sometime when I adjust the cabinet size, it does not adjust certain things. I guess that was a good example of that.
Thanks again!
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
I got another corner that it needs to go into to. It is just a big and odd room. It is one of those where the kitchen is in a "U" shape and they want cabinets on the other side as well.
Big job...
Sergio Fetter
Designer Specialist
Sergio Fetter wrote:No video card. I never had a problem without the video card except for that now.
Using an embedded graphics adapter steals memory from the system.
Sergio Fetter wrote:I got another corner that it needs to go into to. It is just a big and odd room. It is one of those where the kitchen is in a "U" shape and they want cabinets on the other side as well.
Big job...
The bigger and more complicated the job, the more you need a good graphics adapter with dedicated memory.
Since this is a business laptop and not a mobile workstation, you can expect problems with any job that is complicated or large.
