Hi guys, I need some help adjusting my offset settings. When I try to set my offsets an error occurs and shuts down the program. Any suggestions?
HELP offset error
Re: HELP offset error
If you are using the G52L# method for offsets, it is likely your offset table has been corrupted. To correct this issue, you will need do the following once you've written down any offsets that you can access in the table:
Shutdown the Thermwood software > Go to Windows Explorer > find C:\offset.tab directory, Delete file THM.OFF > Then restart the Thermwood software and you should be able to enter values in the offset table.
Thanks Ryan, I'll try it.
