Problem doing a fillet in PE
Hey Guys!
I am currently running 6.1 and I am having difficulty cutting a fillet into a part in the part editor. I first give it a rectangle notch and then try to fillet the one corner and it will not work for me no matter how small of a fillet I try.
Any ideas?
-John
Any ideas?
-John
- Kerry Fullington
Re: Problem doing a fillet in PE
Hi John,
Inside corner filets were a problem during Beta testing and it looks like they didn't get fixed before the release.
Thanks Kerry!
Do you know if this is on the list or should I post it in the Beta forum?
- Ryan Callahan
John,
Kerry is correct, this has been an issue and did not make this release. No need to post this on the Beta forum.
However, there are ways of working around this for now. You can create your cut path in the contour mode of the Part Editor. Once you have a path created, you can cut or pocket this path in the part editor. This is a bit of extra work, but at least it will allow you to do what you need.
If one way does not work, there is usually another to get the job done.
Hope this path helps you out.
Ryan Callahan
Thermwood
Thermwood
Thanks Ryan!
I know how to do the fillet the long way
Great job on V6! It is really a great upgrade.
-John
-John
- Company Name: Penn Laminates
I was just going to post the same problem when I read this, the thing is I did it all the time time in the previous version, just yesterday I made a fan cutout in a AV cabinet 4 3/8 square with 1" radiused corners tried it today in version 6 and it no longer works! What changed in the new version?
Hi Terry!
The difficulty of making changes to the software is that it can cause adverse effects to other areas of the software. V6 was a huge renovation, therefore the long beta testing. I'm sure, as the programmers continue to improve Ecabs, this will be fixed and other areas will continue to get better.
-John
-John
How do you do the inside fillets the long way?
Take your part into the "Part Editor" then go into the "Contour Edit"Terry Davis wrote:How do you do the inside fillets the long way?
Create a rectangle using the "Line Mode."
Click the "Fillet" button and it will ask you for the radius you would like.
Then hover over each of the 2 intersecting lines and select them when they turn red. Once you select the 2nd line it will automatically radius the corner.
-John
Thank you sir, that will work for me....
