I am trying to upgrade my cureent version with the new but getting a 1720 error message:
Product: eCabinet Systems 6.0 Build 1 -- Error 1720.There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom action ReadUsersGroupName script error -2147467262, SWbemServicesEx: No such interface supported Line 1069, Column 3,
(NULL)
(NULL)
(NULL)
(NULL)
I have read the other posts about this error message, even tried installing it a few more times after rebooting my pc, still it will not install. Can someone help me with this problem?
Rebuilding the WMI Repository
If you experience behavior when using WMI, such as application errors or scripts that used to work are no longer working, you may have a corrupted WMI repository. To fix a corrupted WMI repository, use these steps:
Windows XP and Windows Vista
Click Start, Run and type CMD.EXE
Note: In Windows Vista, you need to open an elevated Command Prompt window. To do so, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator.
Type this command and press Enter:
net stop winmgmt
Using Windows Explorer, rename the folder %windir%\System32\Wbem\Repository. (For example, %windir%\System32\Wbem\Repository_bad). %windir% represents the path to the Windows directory, which is typically C:\Windows.
Switch to Command Prompt window, and type the following and press ENTER after each line:
I have rebuilt the wmi repository and still no such luck. Something I forgot to mention. Since I do not have high speed at my location I saved the file to a thumb drive from another computer. Is it possible that something could be missing or is it just my computer. I guess I can try to save it to a cd and see what happens.
