Hi Guys,
I have found myself in another trouble with a drawer cabinet. I am trying to insert drawers in a way that a base cabinet would have two full drawers on the bottom then split the gap left on top with a partition with bottom inset so the partition end up the right size and then put two more drawers in the split opening on top. The program picks the right size 6" but "Adjust Top" and 'Adjust Bottom" won't work. I will still make it work the way I want.
I am just bringing this one to the attention of the programmers.
Opening Problem - Can't insert drawer properly
- Georgi Baltov
- Attachments
- U03 B 38 7-16x 30 1-2x 23 1-2.hsf
- (2.16 MiB) Downloaded 293 times
Top Notch Cabinets
- Ryan Callahan
Re: Opening Problem - Can't insert drawer properly
Georgi,
I am looking at this cabinet, and it seems that the drawer box is placing, just no where near the correct place. It seems that since you are using a top partition as a divider, it is getting confused on where the bottom the the drawer should place, even though the selection seems to be determining the size correctly.
I am going to issue this to be fixed in future versions.
Thanks for listing this.
Ryan Callahan
Thermwood
Thermwood
