Need outsourced ecabs programming
BenRatt
Anyone out there want to do some ecabs programming? Basically it would be looking at a PDF shop drawing, then taking my seed cabinets, modifiying them as needed, and putting them in a batch. Commercial type stuff. We use confirmat /dowel construction using the KD fastener option. I have a checklist that you would need to go by for each cabinet. Once the batch is done you would need to do a basic drawing in LDE showing confirmat hole dimensions for each cab. Need to be able to use part editor to place holes for adjustable legs, door pulls, and locks (I have a spreadsheet to help with that). I haven't upgraded to 6.0 and probably won't for a while, so if you have 5.2 bld 6 running it is a plus. Probably 10-20 hrs a week.
