Is it possible?
Derrick Monson
Is it possible?
Post by Derrick Monson »
1. I was wondering if there is a was to add a manufacturer to the manufacturers list in the define hardware utility.
2. Is it possible to add banding to shelves or stretchers? EDIT: Duh, need to add the part first. LOL
3. There are two options to add drawer glides through the new blue menu on the right side of the screen, Drawer slides and Dbx. Slides. Are they there for separate applications?
Thanks for the help!!
Derrick
Gateway E6100 / Pentium 4 / 2.8GHz / 2.56 GB RAM / Radeon X1950 Pro XGE 256MB / XP Pro
Dennis Englert
Re: Is it possible?
Post by Dennis Englert »
1. Adding manufacturer's. Go to Settings and Preferences>Define Hardware. Click on the Manufacturer's tab. Type in the pertinant information on the rightside, then click on Add.
2. A drawer box can be installed indepedently or with a drawer front. Therefore, you have two different installations and the possibility of using two different slides as well as parameters, i.e., insets, etc.
Hope that helps a little.
Dennis
Derrick Monson
Re: Is it possible?
Thank you Dennis!!
