What is the 'Use Hoops Display List' refering to in the settings preferences?
Whether this setting has anything to do with this but I keep getting an error saying 'An error occured while adding HOOPS information to save the file'.
Can anyone shed some light on this.
Hoops Display List is a Hoops settings that may or may not increase preformance of very large hoops models. Although, some times you may see unexpected visual results when using Hoops Display List. Ex. If you change the tiling or stretching of a texture on a wall or floor in render view while display lists is turned on, it will not update proper on the screeen until you go back to the main area of the Kitchen layout and then return to the render view.
