Nat Wheatley
Posts: 491 Joined: Wed, Apr 15 2009, 8:22PM
Post
by Nat Wheatley » Fri, Feb 26 2010, 11:41AM
In part editor, are you supposed to have the ability to fillet the corners of a cut out? I had thought you could in V5, but maybe not. It does work on the outside corners of the actual part, but not on the cutout.
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Fri, Feb 26 2010, 12:49PM
Nat,
You should be able to fillet inside corners but it looks as though that didn't get fixed.
You will need draw your cuttouts in contour, fillet them and then cut them out.
Scott G Vaal
Posts: 1740 Joined: Tue, May 17 2005, 12:44PM
Post
by Scott G Vaal » Fri, Feb 26 2010, 1:38PM
Nat,
Kerry is correct. This issue unfortunately did not make it in build 2 (but is not forgotten!). You will need to create the geometry with the fillets and then cut it for now. Sorry for the inconvenience.
Nat Wheatley
Post
by Nat Wheatley » Fri, Feb 26 2010, 3:18PM
Got it, thanks for the replies. -Nat
