Door/Drawer Front Designer Errors - V6 B2
Joe Dusel
Post by Joe Dusel »
Open Settings/Preferences dialog.
Change User Data path. (I set mine to c:\ecabsdata2). The select OK.
After the data has been copied to the new location select the Door/Drawer Front Designer.
Select Doors, then Select Door Source of Conestoga.
Select the Standard directory.
Select any door. The Image Not Found should now be displayed for the door while the door still shows in the view.
Save the door in a directory named "test" (or whatever).
The following error messages should now occur:
An error occurred while adding HOOPS information to the save file.
Jpegfile: Can't open c:\ecabsdata2\doors\saved\Conestoga\test\CRP-10318.jpg (Your location and filename.)
Unable to open ECabinets file data.
Syntax error (missing operator) in expression.
Joe
CFT411 http://www.cft411.com
Joe Dusel
Re: Door/Drawer Front Designer Errors - V6 B2
Post by Joe Dusel »
UPDATE:
I re-ran the V6 Build2 installation and the problem is fixed. Apparently there are problems associated with changing the User Data Path. This is the second computer on which I had this problem.
Joe
