Cabinet Losing Constraints
Nat Wheatley
Post by Nat Wheatley »
When I change the width of the attached cabinet, the holes for the leveling legs don't follow the constraints set.
Pref_Base_Std_Pair_2_ROT.hsf
(1.16 MiB) Downloaded 632 times
Justin Friesen
Re: Cabinet Losing Constraints
Post by Justin Friesen »
I am also having this problem but with part editor cuts. Everytime I change a cabinet in width I lose my part editor cuts but only on my fixed shelf. I have part editor cuts on my deck and top as well but they don't seem to be effected. I have all my holes constrained but that doesn't seem to help from losing them on my fixed shelf.
Justin
Ryan Callahan
Post by Ryan Callahan »
Nat,
I have listed your cabinet to be reviewed as I am not seeing anything wrong with it.
Justin,
I have been trying to reproduce your issue using a Std Base Frameless with a Fixed Shelf.
Add PE cuts to the shelf, add constraints
Resize in multiple directions, and I am not getting this to happen.
Can you please post a cabinet for me to review with very simple parts. The simpler the cabinet, the easier it is to see the problems.
Thanks.
Ryan Callahan
Thermwood
Nat Wheatley
Ryan,
When you resize the cabinet to 18"/457mm, do all the holes for the leveling legs still appear? There are several holes missing when I do it.
Ryan Callahan
Nat,
Problem has been resolved for the next Build.
Thanks for posting the issue.
Ryan Callahan
Thermwood
