Can pulls or knobs be added to a finished kitchen in 1 fell swoop, or do they have to be on the cabinet in your library before you put them in the room?
Rick
Adding Pulls or Knobs
Joe Dusel
Re: Adding Pulls or Knobs
There must be a pull selected in the Cabinet Editor in order to change the pulls. If you normally don't want the pulls to show you can check the Mark Location Only check-box when adding the pulls. (Note: This is apparently currently broken since rendered pulls are showing up in the Custom Layout Editor when Mark Location Only is checked.) Adding the pulls in the Cabinet Editor sets up the location and rotation for the pulls.
When in the Custom Layout Editor you can select all the cabinets you wish to show pulls on, select the Adjust Features/Door or Drawer Pulls and then pick a pull (with a rendering) that you would like to display.
Joe
Joe
CFT411 http://www.cft411.com
So I am assuming that my library cabinets have to already have the pull locations marked for that to work and before I install them in the room? Thanks Joe.
