Lingering image
Lingering image
Hi Guys
Sorry I haven’t read every post so this has probably already been reported
This is what you get when you take your cabinet to the CE from the custom layout and delete the associated hardware. Return to CL and there they are!
A kitchen full of giant drawers.
Sigh.
Fortunately you can save and restart without the glitch. :)
Re: Lingering image
Hi Mark, can you post the job file.
Re: Lingering image
Hi Rick
Yes I will, by the way can you look at the sizing in the above picture? See the position on floor left dimension. It has a decimal place too many, and I am unable to change it. I gave up on the job until I have more time to sort it.
I am not proficient in the custom layout area so it may just be me doing something wrong.
Also in elevation view I can't seem to work out where the 2mm dimension is comming from. Any pointers greatly apreciated :)
Re: Lingering image
It may just be the assembly of drawers on wall 4. I took it into the Cab editor and returned it to the custom layout without doing a thing with the same result. I used this assembly as a seed for the unit on wall 2
(Normally I would have used the constraints in the drawer construction settings but I had given up on the drawer constraints manager at the moment, It was giving me hell and I couldn’t tell if it was just me or a glitch, so I made assemblies instead)
Also when I try to delete the slides from the units and take them back into the custom layout I can’t delete them. Again it may just be me, as I am just trying to learn more about these areas.
Previously I would set my kitchens or jobs up in the cabinet editor as assemblies, but I like the look of the new layout area and the adjustment features in the custom layout area are much better.
So it is probably worth the time to learn it.
LindaFordy.esj
(3.1 MiB) Downloaded 506 times
