Can't Nest !!!
DanFecteau
Can't Nest !!!
Post by DanFecteau »
I had control nesting 5.52 and I was not able to nest this job, same problem with 5.53....help please. The .doc is the twd file.
Meuble.doc
(288 KiB) Downloaded 576 times
Meuble.esj
(1.63 MiB) Downloaded 539 times
Re: Can't Nest !!!
Post by Ryan Hochgesang »
Dan,
Could you please explain in more detail what's happening or what error your getting? I will also need a copy of your EXPORT file from Control Nesting for review here. You can send this information to: program@thermwood.com
Thanks!
Re: Can't Nest !!!
Dan,
Perform the following steps with the TWD software shutdown:
1.) Delete c:\Rolling Nest\history.mdb (DELETE only the "history.mdb"
file)
2.) Run Latest install (Full or Repair)
3.) Start Control Nesting and go into SETTINGS and change the "Keep Recut
History" to zero
DanFecteau
Re: Can't Nest !!!
Problem fixed !! Thank you.
