Walls, assemblies and cabinets loosing associations
Post by Donald Thomson »
I go through the process of associating a cabinet, assembly, appliance, etc. to a wall. I then select the wall and press 'W' to see the wall view so I can move the object up or down on the wall. I get to the wall view and the associations for some of the objects are lost. For example a sink I'm trying to place in a sink base cabinet keeps loosing wall association. I go back to top layout view, re-associate and try again with the 'W' command. This time the sink is there. Go back to top view and 'W' view, sink association is gone and I have to go back to top and re-associate. I've attached the file where this problem seems to be occurring. Makes it kinda time consuming to try and get things located properly... :?
Butler Kitchen V6.esj
(1.82 MiB) Downloaded 300 times
Re: Walls, assemblies and cabinets loosing associations
Donald,
When I opened your job the sink was associated to the left hand wall and is still there after going to the elevation view. I have associated it to the other two walls and they seem ok also
Maybe it is an operating system problem. I am using XP Pro.
I'll keep playing with it.
Donald,
If I move the sink around in the overhead view it does lose it's wall associations.
Thanks Kerry,
At first I thought it might be a machine specific problem. I run Windows 7 on 8GB RAM with a quad core processor. I just never know whether it's a eCabs bug or a situation/configuration of my computer. I'm still running into intermittent crash problems with build 3. Also running into real SLOOOOWWWWW downs in the software after running for about 15 minutes.
Based on your ability to repeat this I do believe this is a bug that needs to get logged by Thermwood. As I am not a beta tester and I think you are, could you post this onto the beta forum as a repeatable bug or should I send a bug report via email directly to eCabs support?
Thanks again.
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
Donald Thomson wrote:Thanks Kerry,
Thanks again.
Posting here will get any bugs logged by Thermwood. No need to go to beta forum as that is for beta releases. Also, if you are having crashes, you need to report this. If it crashes, list the steps that you were doing, maybe a possible hsf or esj file, and maybe a possible screenshot of any error descriptions in the event viewer that are associated with ecabinets.exe. We cant fix it if we dont know about it. If you are having a problem, then most likely other users maybe have the same problem.
Rick Deskins
