Base Angle Cabinet
Paul Bruce
Base Angle Cabinet
Post by Paul Bruce »
How can I add doors to a cabinet like this? All I did was put a front inset on the left end and angled the top and deck in the part editor. When I try to add doors it still applies them as if it were a full depth gable.
Base Angle 30.esj
(12.02 KiB) Downloaded 774 times
Paul Bruce
Re: Base Angle Cabinet
Sorry, not sure if that file worked, here is a jpg. of the cabinet.
base angle.jpg (52.61 KiB) Viewed 12429 times
Sean Jakob
Company Name: Sean Jakob Cabinets
Post by Sean Jakob »
You have started with a standard cabinet. Start with a corner cabinet instead.
Then go into the construction settings and under the Corner settings, you can tell it to have an angled front.
It should all become self explanatory from there.
Paul Bruce
I'm not looking to create a standard corner cabinet with and angled front. This is an angle cabinet that would go at the end of a run of cabinets. If I try to start with a corner cabinet I would have to somehow place a door where the gable is.
If I start with a standard cabinet I can add doors manually and place them using align part but I can't get the hardware holes to show up.
Sean Jakob
Is this the sort of cabinet that you mean?
It was created with a corner cabinet, yet it is used to finish a run of cabinets (at the entry to the room, not back in one of the corners)
created from a corner cabinet
BCLIP LH.jpg (5.88 KiB) Viewed 12389 times
Here is another
and another
and another
Angle Front 600_450 LHS Display.jpg (9.19 KiB) Viewed 12389 times
Paul Bruce
Yeah exactly, but I want two doors on it - one on the angle and another on the front. Do those have two doors?
Thanks.
Sean Jakob
No it only has a door on the angle, but it does have two fixed panels in the two faces adjacent to the door. These were added as display parts.
Hope this helps
