Hi there,
I have a problem with the load screen in 5.59 being very slow to respond. It can take 5 mins to clear a job, twice that to load. I dont think it relates to file size, it can be as slow with a few panels in manual panel input. It first ocurred with 5.58, tried defragging & running repair to no avail. Any ideas would be appreciated.
Thanks.
Load screen running slowly.
Sean O' Hare
- Brad McIntosh
Re: Load screen running slowly.
Sean...
Are you using the RECUT feature? If you are not, you may want to try the following:
1. Go into SETTINGS and set the RECUT HISTORY DAYS to 0 (zero).
2. Close THM.EXE.
3. Delete both "history.mdb" and "history_save.mdb" in the c:\Rolling Nest\ directory. (Do NOT delete "History_install.mdb" as it is not related to the RECUT feature.)
4. Restart THM.EXE.
See if your LOAD management speeds up.
2. Close THM.EXE.
4. Restart THM.EXE.
Sean O' Hare
