How are you guys joining the back of your corner cabinets.
I would like to use my router to cut a 22.5 degree bevel edge for joining with adjacent back to create one of the two 45 deg joints in the backs of a corner cabinet with clipped corner.
could it be as easy as drawing the profile cut in e cabinets and picking the right tool in mdf door settings to cut this part in a nest.
corner cabinet mitered backs
Jim Carter
- Company Name: Jim Carter Corp.
Nick M Singer
Re: corner cabinet mitered backs
Hi Jim
It could be done that way but would probably be simpler to do those parts as DXFs and specify the correct cutter there.
Jim Carter
Cutting a 45 angle in a nest
I found this discussion last night, and it answers allot of my questions.
But I wonder about the DXF file you are creating, and nesting.
Do you create a different file for each size you will be cutting, then check off the backs which need mitering in the e cab file?
To cut this miter one at a time after they have been cut to size in a nest,has any one developed one jig to profile one edge on any size piece?
Where have you found 22.5 deg bits? I did not see any in the online store.
Jim
Jim
Nick M Singer
Jim you would create a seperate DXF for each part. I would make the backings in my eCabs drawing out of a "no machine" material so I could get the correct sizes for the DXFs. As far as my own experience is concerned I do not cut the miters on the CNC but cut the back panels oversized in the nest and cut the bevels on a panel saw. For the number of backings one would have to do for a relatively infrequent situation it is the easiest way I guess without the investment in special tooling.
Jim Carter
thanks Nick
you make allot of sense.
JIm
JIm
