Change Door Color?
John J. Desmond
Change Door Color?
Post by John J. Desmond »
Can anyone tell me why I can't change door colors? I am using the CRP-10 Conestoga door. This is the one I usually use. I have the color in my board stock with all the information but it won't change. I have done this many times before with not problem. It seems that since upgrading eCabs I can't do it anymore. Any help? When I change all the door settings the reset view button does not light up. It seems as though I can't do anything.
John
Leo Graywacz
Re: Change Door Color?
Post by Leo Graywacz »
Go into the construction manager and go to face frames. Go to the 2nd page. There you will find a check box that will match the door to the faceframe stock. Uncheck it and you should be able to use the match texture command to change the grain pattern/color.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Dennis Englert
Post by Dennis Englert »
John,
Not sure what you are doing, but in Custom Layout select the cabinets that you want to change the doors on. Then go to the Item Window and select the "Adj. Features" button. Click on Doors at the top of the list. Then select the door you want in the Door Drawer Designer and modify the door by selecting the finish, etc. Then click the OK button. The replacement door is installed. If it is a face frame cabinet, that finish won't change unless you have the option on "Go to Page 2" checked.
So from I can see this feature does work, but it was moved to the Item Window.
Dennis
