Unresponsive Cabinet
JohnLashuay
Post by JohnLashuay »
Here is a small cabinet that after I added doors became relatively unresponsive, meaning I cannot modify in the shelf/partition editor. In the CE only rotate function works, but not zooming in and out. The cabinet seems to be set back even when I home it.
I regenerated it -> no difference. I deleted the top shelf so the doors would be removed and still no change.
Any ideas?
-John
Mud_Wall_04x36x28_Cork.hsf
(626.02 KiB) Downloaded 303 times
http://www.rylexonline.com
Thermwood CS 43
Company Name: Halls Edge Inc
Re: Unresponsive Cabinet
Post by Josh Rayburn »
Unresponsive for me too. It has part bodies, but I can't select the cabinet or do anything to it other than rotate.
JohnLashuay
Josh, I had the same thing until I regened it and then the cabinet appeared. I have no idea what I did, just was curious if anyone else had seen this before.
Thermwood CS 43
Scott G Vaal
Post by Scott G Vaal »
John,
This cabinet is really messy. If you can show us how to reproduce this again, we would like to know.
JohnLashuay
Scott, I tried to reproduce the problem, but I am having no luck! I'll let you know if I come across it again.
Thanks for checking into it!
-John
Thermwood CS 43
