If I take a cabinet with doors and drawers into the FF editor and move the FF positions around by resizing the openings, when I come back to the cabinet editor (Main) the drawer boxes will resize correctly but the doors and drawer fronts will remain at their previous sizes. I makes me go into the door/drawer editor and delete them and reapply them. Is this how it is? Or am I having issues?
I am using the dbx editor to insert my drawer boxes because I need them to be specific sizes (height). I put that in there in case it matters.
If you move a mid-stile or mid-rail the doors will not re-size. You must take the cabinet to the Door Drawer Front Editor and remove/replace them.
Just the way it is.
I agree that something needs to be done about this. If you move the mid stile or rail very little you may not notice that the doors and drawer fronts did not re-size properly and you will either build or order wrong doors. If they can't make the doors and drawer fronts re-size properly in this situation then there needs to be a warning pop up or the the doors and drawer fronts need to be removed by the action of moving the stiles and rails.
