Texture Match?
John J. Desmond
Texture Match?
Post by John J. Desmond »
When I put a door on a cabinet it changes my face frame to the wood and color of my door. Isn't the door supposes to be able to be changed to match the face frame? The face frame still says it is the color I originally set but is now the same as the door. What am I doing wrong? :roll:
Re: Texture Match?
Page two of Face Frame settings, uncheck Finish Common with Door.
Dennis Englert
Re: Texture Match?
Post by Dennis Englert »
The setting on Page 2 causes the face frame to match the door. There are no settings to make the door match the face frame. If the check box on Page 2 is unchecked, the the face frame's texture won't change and the door's texture will be what it is. In other words, you could have two different textures and nothing matches.
Dennis
