Hi - this is a recurring "issue" - I use the quotes because I'm not sure if it's an issue or just my problem. When cutting doorways into walls, if the "build direction" of that wall has been reversed, the cutout always appears flipped. Meaning, if I try to cut into the left side of the wall inside the room, it shows up on the right side (as if it was cut on the left side of the wall from OUTSIDE the room).
I know this may just be a case of me remembering that the wall has been built opposite to the regular direction, but I'm wondering if there's a fix for this?
