Prior to 4.79, DXF files run through rolling nest used to always drill first. Now even after putting a 1 after the drill layer name (drill1 z0p76) and a 2 after the dado layer name (dado2 z0p376) the dado is cut first. This is causing huge problems for some of our designs where we drill pilot holes that are bisected by a blind dado.
The 1/8\" bit just snaps off when you try to drill on the edge of a dado.
Please fix this.
Can I revert to an earlier RN version by installing the update?
Dave
Rolling Nest Problem - Order of operations
David Hall
- Attachments
- finished left end back.zip
- (990 Bytes) Downloaded 907 times
Josh Meyer
Josh Meyer
Dave Burtchell
David Hall
OK, that got me through today. If I specify drill layer as Drill1 and the dado layer as dado2, for all parts on the sheet. It does the drilling first.
Drill1 and dado2 on just one part on the sheet doesn't work. (at least when the part is part2)
Can we put the default order of operations back the way it was? Pleeease.
I have standing files that must now be reworked for no good reason. I like the new features that let me control the order of operations. This is a powerful addition that let's us do more with DXF files than ever before. BUT, the new default order is causing major headaches. This is broken.
Thanks for the quick work.
Dave
Dave
Josh Meyer
