Hey guys im Having a problem i keep getting a random error Pops up on my Screen Siemens feed module Error it is different spots everytime.... and sometimes it will run through the hole program without any errors plz help im goin nuts
First thing you should do is check all the plug connections at each motor to ensure they are cleaned out and also fastened securely. If you continue to have issues, it would be best to contact Thermwood's service dept. with your specific machine # and explain fault error your getting. They will then give you further instructions on what to check within your control cabinet.
