Just checking to see if there is an easier way. I build frameless and in a tall kitchen I will often stack cabinets..I always build pantry cabinets with a lower and an upper cabinet stacked directly on top of it. I also build in metric..which is pertinent because the numbers are not really recognizable and long. To make things even more complicated this present house has a cathedral ceiling, so all the walls are different height.
In this job the top cabinet height 2188mm above the floor. Now..at a glance by selecting a cabinet is there a way to see that the cabinet is at the right height? The only way I have been able to check is to go to plan view, write down the wall height, go to elevation view, select the cabinet and subtract the TOP measurement from the wall height. Ditto for then trying snug up cabinets underneath.. for example in this layout, to set CabA below CabB, I had to do the following operation...3.7846m wall height (try and remember that number!) - 1.5966m Top measurement = 2.188m which is the correct height for CabA, then take the BOT measurement for CabA, subtract it from the wall height..3.7846m-1.868m = 1.9166m, which now becomes the top measurement for CabB. Boy it would be easy to have CabA's BOT measurement be the same as CabB's TOP measurement if it is right under it. CabA's RIGHT measurement is not adjacent CabB's LEFT number. If cabinets overlap a few millimeters and I don't catch it I'm screwed.
Anytime I have to turn to a calculator or type formulas it slows things down and opens up room for error. My overall question is why are the location measurements referenced from separate points, ie. top from top, bottom from bottom,etc. when you never measure like that in real cabinet life. Always measure from the same point. When I install, I never measure from the ceiling down to set base cabinet height..nor do I measure from the floor to the bottom of upper cabinets, or from the ceiling to their top.
At a glance none of the reference numbers are recognizable. The base cabinet and upper cabinent heights are all different even though they are the same size cabinets depending on what wall they are on. I had this problem trying to set doors and windows, too.
Am I the only one who finds this confusing or is there a preference to be set or a way to figure this out..or do you just get used to working this way.
