labels reformat???
J A Rains
- Company Name: Frost Keading
labels reformat???
How can I reformat the labels? I would like to swap lines 3 and 4 with each other. The layout would be: line 1. part name, 2 Cab #, 3 Job name, 4 Sheet #, 5 Material. I am using the Dymo Labeler on a C45 router
- Kerry Fullington
Re: labels reformat???
J A,
I think you will have to have a copy of the Crystal reports Software to be able to edit label formats.
J A Rains
Thanks Kerry, I don't have Crystal software. Any other way?
- Kerry Fullington
I think Crystal Reports is a must HERE is a link from 2006 about this same topic. Search Label format for more.
- Brad McIntosh
Crystal Reports 8.5 is currently needed to modify or create new labels RPT files. This is an older version that may still be available via Amazon or other sources.
Note! - The newer versions (9, 10, 11+...) cannot create RPT files that are compatible with the current reporting engine used in Control Nesting.
- Josh Rayburn
Brad,
Is this a service you would be willing to provide? Assuming you do have the software?
- Brad McIntosh
Josh,Brad,
Yes it is a service we offer to our Canadian clientele.
You should first contact Ryan Hochgesang in Thermwood's Software SUP/Programming Services department, as I believe this is a service that they offer as well.
- Josh Rayburn
Thanks Brad, will do. I've been thinking about that for two years and it's one of those things that I just haven't gotten around to lately..........in the past two years...
J A Rains
Thanks to everyone for the replies. JR
