Resizing problem or repository for sick cupboards
I haven't had this one happen to me before. I did a quick search. but couldn't see anything.
I must have rampant negative neutrons, quarks and baryons flowing from my fingers into my computer processor, disrupting its normal rhythms, It’s that kinda day.
The last 3 units on the right hand side have been resized, they show the correct size when highlighted, but when you do a cultist they are still the original size.
I don’t need an answer. I just put them here as another little curiosity to filed into that mysterious file or place where all sick little cupboards go, so that one day the good programmer doctors can pull the poor little things out and repair them. :joker:
Seriously though. At first I thought it was really cool how they resized and automatically pulled the unit next to them along, and then not having to do the realign to zero process.
josh treat1 Base broken.jpg (8.38 KiB) Viewed 2935 times
Scott G Vaal
Re: Resizing problem or repository for sick cupboards
Post by Scott G Vaal »
Mark,
If you can give us an actual cabinet or assembly file {.hsf or .esa} with the steps you take, we can take a look at this and see if we can figure what you are seeing.
Sorry about that.
I deleted the previous 3 faulty cabinets and started again but the same thing happened to the set of drawers again in the repeat.They say 552mm wide but if you high light and do a cut list they say 600mm.
As for steps. I just clicked to load. Nothing different to the usual. highlighted the cabinet and resized. realigned. I didn't fully pick up differences untill things didn't line up with the top cabinets.
The 3rd time seems okay.
Mark
josh treat1 Base good.esa
(2.86 MiB) Downloaded 316 times
