Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
darren m harvey
Posts: 22 Joined: Mon, Aug 02 2010, 1:37PM
Company Name: bobcad-cam
Post
by darren m harvey » Tue, Jul 26 2011, 8:20PM
has anybody ever cut kerfcore on their router. if so how did you hold it down, what bit, feed/ speed rate. thanks for your help Darren
Posts: 1263 Joined: Wed, Jul 01 2009, 2:19PM
Company Name: Halls Edge Inc
Post
by Josh Rayburn » Wed, Jul 27 2011, 6:34AM
Hi Darren,
Yes, it must be cut with the smooth face down so it holds down to the table, and I used standard MDF tooling. Nothing else special.
darren m harvey
Post
by darren m harvey » Wed, Jul 27 2011, 6:48AM
thanks Josh for the reply. when you say MDF tooling what tool is this. we were using a 3/8 compression bit. thanks again, Darren
Post
by Josh Rayburn » Wed, Jul 27 2011, 6:58AM
Compression spiral for outlines and whatever other tools you need for dadoes, etc. Or if you are having hold-down issues, you can use a down cutter to outline but that pushes all the dust down into the wasteboard and does not extract well, so I will use a compression spiral as often as possible.
darren m harvey
Post
by darren m harvey » Wed, Jul 27 2011, 12:33PM
hold is another issue but we are thinking spraying laquar on the back to hopefully for a better hold down. thanks again for all you help, Darren
