Control Nesting Problem, "too few parameters, expected 3"
This is the first real problem I've encountered with our CS45. I tried to nest an ecabinet part with two pockets and it must have corrupted something. Every time I try to load a job, dxf or cut list I now get "too few parameters, expected 3" and the job won't load. If I hit "add" instead of "load", the job will load but when I try to nest I get the same error. I've tried updating control nesting and doing a system restore; now I'm out of ideas. Anyone have a clue as to what's going on?
- Brad McIntosh
Re: Control Nesting Problem, "too few parameters, expected 3
If you are not using the "Recut" feature, try this...
On the controller,
Hope this works....
On the controller,
- Place the machine into E-STOP and close THM.EXE.
- Use My Computer or Explorer to navigate into the "C:\Rolling Nest\" directory.
- Find "history.mdb" and delete it. (Don't worry an empty one will be recreated.)
- Find "history_save.mdb" and delete it. (Don't worry an empty one will be recreated.)
(** Do not delete "History_install.mdb". It is unrelated to the other two.)
Hope this works....
Ok, this worked. Thank you very much.
