Rotating a partition
Richard McComas
Post by Richard McComas »
I'm not real savvy with the software at this point.
I'm trying to design a double sided library book shelf. I need to rotate the hi-lighted partition in the image to divide the case in half. Or in other word rotate the partition 90 degrees. Is there a way to do this?
Re: Rotating a partition
Richard,
You will have to use a stretcher to do this. Or you can inset the back and then use negative insets on the top and deck.
You will need to cut some of the shelf holes manually any way you go.
