Vacuum less effective
DanFecteau
Post by DanFecteau »
Looks like our vacuum is less effective than it was, we have not change anything lately. Is it possible that the vacuum pump become less effective over the years ?
jason galbraith
Country: AUSTRALIA
Re: Vacuum less effective
Post by jason galbraith »
They will need a service/rebuild in their lifetime. We've had both of ours rebuilt. They are about 7 years old.
www.eastcoastultimate.com.au
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
Dan,
It is possible that your vacuum pump may need maintenance. Over the years the seals, etc can become worn and efficiency can be lost. You may want to contact CNC Automation's service department and speak with one of the technicians.
Some additional things to check things to check:
  • Have the pumps filters been changed recently?
  • Is the seal under your main spoilboard intact (no gaps, no rollover)?
  • Has your main spoilboard been resurfaced recently to reopen/roughen the mdf?
  • If your main spoilboard has been recently replaced, was the underside also surfaced in order to open up the sealed factory "finish" (by 0.020"-0.050")?
Our service staff may have other things for you to check.
You can contact CNC Automation's Service Department at: 1-866-947-5527
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
DanFecteau
Is there a way to "test" the vacuum pump before having a guy from bush coming to check it ?
Will Williamson
Post by Will Williamson »
if you are desperate. disconnect the vacuum hose and block off the pump inlet with a piece of mdf start with 50 % blockage aand advance to 90% looking at your gauges
Will
http://www.willmade.com
