error: appropriate start point?
Jim Carter
Company Name: Jim Carter Corp.
Post by Jim Carter »
when I nest the loaded parts in x or y direction I get the following error message.
"Error appropriate start point for outline opperation 12 on panel not found.
this is on my desk top , then when I go to Write CNC I get the following error.
Encountered an improper argument.
any body know how to fix these errors?
thanks
ControlNest5-68.zip
(77.85 KiB) Downloaded 544 times
jim@jimcartercorp.com
973-224-0221
Ringwood, New Jersey
Brad McIntosh
Company Name: CNC Automation
Re: error: appropriate start point?
Post by Brad McIntosh »
Jim,
Can you also include (upload) a copy of the source of the job? Was it a TWD or a layered DXF?
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Jim Carter
Yes Brad
attached is the TWD file, extension was changed from TWD to txt.
thanks
12-3-16 teeters.txt
(146 KiB) Downloaded 565 times
973-224-0221
