Slowest RPM
Company Name: Halls Edge Inc
Slowest RPM
Post by Josh Rayburn »
Does anyone know the slowest RPM the spindle can run on a TWD router? The reason I ask......Has anyone tried a forstner type bit in a toolholder?
Dennis Englert
Re: Slowest RPM
Post by Dennis Englert »
Josh,
Most of the cabint shop machines are rated at 4000 rpms at the lowest, but torque is lost as you go down. So don't know if you could turn the forstner bit and cut effectively at that rpm/torque. I would bet that an interperloted (pocketed) hole would potentially be faster.
Dennis
Re: Slowest RPM
Cool, thanks Dennis!
Jeremy Schiffer
Re: Slowest RPM
Post by Jeremy Schiffer »
Josh, we run a program in which we use a regular run-of-the-mill 3/8" drill bit to drill holes through plastic. I run it at either 3000 or 3500 RPM (can't remember which right now) and it does just fine. Just be mindful of the plunge speed, and I'd be willing to bet a forstner bit would work fine at 3000-4000 RPM, which is what most hand-held drills run at.
CS-41 4x8
CS-45 5x12
BenRatt
Re: Slowest RPM
Post by BenRatt »
I run Forstner bits a lot. I use a 20mm for rafix fittings everyday. Just ran 1.25" for a special run. I think I run them at 10k and 100 imp plunge.
Ben Ratterree
Blue Ridge Cabinetworks
Spartanburg, SC
http://www.blueridgecabs.com
