We are running v4.81 and I have experienced this problem with flip operations. At first I thought I was seeing things.
I cut a cabinet box that had two partitions that were blind dadoed top and bottom. On the flip operation cutting the dadoes it cut one dado but not the other.
I just cut two partitions between cabinet areas that will have adjustable shelves. On the front operation it cut all the holes correctly (two rows of 35 holes on one, two rows of 5 on the other). On the flip operation for the longer partition it cut just a single line of 5 holes. On the shorter piece it drilled just a single hole.
Has anyone encountered this? Is there a fix in the works? Since I just sold my line boring machine a week ago, this is kinda important.
I just upgraded Rolling Nest to v4.84 and it appears to have fixed the problem. I re-ran my program, skipping over the main body and going right to the flip operations. It drilled the remaining holes and lined up correctly on the few that it had cut the first time around.
