When I try and apply a hole pattern to pulls I get the error message "The file does not exists on this system. The hole pattern will not be applied". It actually does apply it, but took me a while to figure it out.
For instance I open a new cabinet, select the pull I want and then select the hole pattern I want. Next I click on the "apply to " icon at the top right and that is when I get the message. It's doing this with multiple patterns.
Ben, I have this error constantly with every hole pattern I apply. I have not seen a negative impact on machining though, it seems like a rogue message. It does go away if you set both the drawer slide mount and the drawer slide pattern to be the same.
