Maintenance history gone
Jeremy Schiffer
Post by Jeremy Schiffer »
What could cause all of my maintenance history to disappear? And is there any way to get it back? I've not updated or changed anything on the controller, just went to do the weekly maintenance, and there's nothing in the list! :(
CS-41 4x8
CS-45 5x12
Will Williamson
Re: Maintenance history gone
Post by Will Williamson »
Your DXF file causes Control Nesting to lock up. You then have to turn off power to Thermwood control panel To restart. BAM you just lost your maintenance schedule. Then a few months later it happens again and again. Now you do not have a clue when your long term maintenance is due. It is gone forever Call Daniel in the morning and he will send you a new file to restart your maintenance.
Will
http://www.willmade.com
Daniel Vonderheide
Post by Daniel Vonderheide »
Go into your C:\system directory and delete the MCLOCK.BAK and the MCLOCK.BIN files. Restart the THM software and the schedule should be reset to the factoory settings now. Hope this helps.
Jeremy Schiffer
Thanks, that got the schedule restored. I'm assuming 4 years of maintenance records are gone, though. Is there something I can do to back up the history occasionally? I see a button called "write file"... is that what it is for?
CS-41 4x8
CS-45 5x12
Daniel Vonderheide
That is exactly what it is for. :D
Will Williamson
So how does that work Daniel? Write file makes a copy of the current maintenance hours?
Will
Daniel Vonderheide
It basically creates a text document that stores what was done and when it was done. Nothing more. It cannot be imported back into the maintenance schedule.
