installing pulls and getting the holes to show up
Frank Wedman
Company Name: Space Attack Inc.
Post by Frank Wedman »
I don't seem to be having any luck getting pull holes to show in doors or drawer fronts. I have created a standard 96mm hole pattern ( 48mm each side of the Y axis, centred at 0 on x) used a positive 3/4" depth, when I view the pattern in 3d it looks exactly as it has been drawn, saved the pattern, in this case as a door pattern. I specify the hole pattern in the pull section of the hardware menu in the door/drawer editor, install the pull using Add/Locate pulls from the menu, specify the location which shows up as a centreline mark on the door fronts, but no holes are put in. When I take the cabinet to the cabinet editor and look at the part in part editor, it doesn't show the holes. Any idea what I'm doing wrong? Frank
Re: installing pulls and getting the holes to show up
Frank,
my Mistake
Scott G Vaal
Post by Scott G Vaal »
Frank,
The manual actually has this stated backwards. You need a negative depth on your pattern to cut into the door and drawer fronts. The positive value is used if you want the holes cut into a drawer box front that would be directly behind a drawer front. We will correct the manual for the next build. sorry for the confusion.
Frank Wedman
A thousand blessings on your house Scott! That worked. I thought I was loosing my mind. Frank
John Castagna
Company Name: DeCarle Cabinetry
Post by John Castagna »
hello, I'm having a similar issue that the op of this thread was having... I ran a search which brought me here. I tried what was suggested in this thread but no matter what I do I cannot view the handle holes. What am I doing wrong!? Thanks in advance
John
