I want to clean up the Manufacturer's tab in Define Hardware. If I remove most of the listed manufacturers will they return when I load a new version of eCabinets.
I have noticed in the past that much of the cleanup I do is reversed every time I load new version or build.
Ultimately I only want information about manufacturers, distributors and products that we actually use.
I would like to eliminate 99% of the Conestoga and Hafele moldings leaving only the few that we need for presentation.
I may be incorrect, but this sounds allot like the problem I was having here with user data not being respected. http://www.thermwood.com/forums/viewtop ... =3&t=13123
I'd suggest that all user-modified data be identified & separated clearly by the programmers so that, among other things, updates do not overwrite user data.
