I am trying to create sort of an inset face frame where there will be L&R stiles and T&B rails. All will have RTA fittings attached to respective ends/top/deck. I can use a stretcher to create the stiles, but since the rails should fit in between the stiles and not go all the way through to the end panels, can this be done with a stretcher?
I don't see an inset function that would allow me to back out the width of the stiles/strtchers. I know I could probably take the rails/stretchers into PE and chop of the ends to fit. Wondering if I am missing something with stretcher function and maybe a new option with recent new build version 9.
Thanks.
Stretcher Situation
TonyGiunta
- Company Name: ToSa Design
- Kerry Fullington
Re: Stretcher Situation
Tony,
Create your Stretcher for a rail then give the left end the proper inset (the width of your stile). Lock that inset then give the right end the proper inset. This will shorten the rail to the proper length then lock that inset. Now if you re-size the cabinet your stretcher will adjust accordingly.
TonyGiunta
Hey Kerry,
My mother was born in Amarillo TX. Have not gotten there yet. Someday.
I don't see an inset function in the stretcher editor? My post may have been confusing regarding me using FF terminology.
Tony
Tony
- Kerry Fullington
Tony,
After you create a stretcher in the Stretcher Editor, click on it to select it then click the Adjust Stretcher button. You will then go to a screen where you have 6 different insets you can place and lock on that stretcher.
TonyGiunta
I never realized you could actually modify the length of a stretcer with those. Good to know.
Thx!
Thx!
