Program Very Slow
Nat Wheatley
Program Very Slow
Post by Nat Wheatley »
I was entering a batch of cabinets today, and things seemed to be moving very slowly. Even changing the names of batch items was taking far too long to register (30 seconds). Saving files, creating .TWD files, and some of the other processes seemed on par with what I'm used to, but others were extremely slow. I'm not sure when this problem crept in
Running Build 10, no changes to hardware. I tried a re-boot, which did nothing to clear things up.
Any ideas why this may be happening?
Scott G Vaal
Re: Program Very Slow
Post by Scott G Vaal »
Nat,
Not sure on this. Does it seem slow even if it is just one cab in the batch? What other areas seem slower than normal for you. Maybe attach a job that is giving you this issue. Is your virus software set to exclude ecabinets.exe and its user data path and app data path? You may also want to update your graphics driver to the latest available (maybe a windows update did something to this).
Nat Wheatley
Hi,
I just tried a sample batch of one item, and it took only a second or two for the item name change to register, so it does seem to be related, on some level, to the number of items in the batch. I've also noticed that it takes quite for this file to open on my computer.
The file is too large to attach here, so I've e-mailed it to you.
Nat
