Hey hows it all going?
I was running a curve on the thermwood and it nested and wrote the code fine and when i pressed go it moved to start cutting it dropped down in to the board then error message came up saying: (in the blue bar) Programe Error 3529
Invalid Syntax in program file.
Thanks inadvance
Thom Davies
Error Message
- Thom Davies
- Company Name: Dawn Group
- Country: NEW ZEALAND
- Thom Davies
Josh Meyer
Thom,
Typically the cause of an invalid syntax in programs created using the Control Nesting Software is due to an invalid material name such as having \"\" in the material name to define inches. Just to give you something to look for. If you don't see anything such as this you will need to send in the cnc code along with the error information and what line it is seen on, and I will take a look at it. josh.meyer@thermwood.com
- Thom Davies
