failure installing library
Ken Klingman
Company Name: Los Trancos Engineering
Post by Ken Klingman »
Hi,
Just became a member of the eCabinet Systems community and was looking at the available
pre-built libraries. Looked like "Stain Grade Face Framed Full Dado Library (210 items)"
was what I wanted, so I downloaded the installer.
However, when the installer starts it almost immediately says:
"Error 1334. The file 'ul_ATL80.dll.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E' cannot
be installed because the file cannot be found in cabinet file 'Data1.cab'. This could
indicate a network error, an error reading from the CD-ROM, o..."
I've had this happen with Chrome and IE8 and with & without eCabinetSystems6 running.
Pretty stock install of WIndows 7 Home Premium 64-bit. The eCabinetSystems6 program
seems to work fine, at least in the little bit that I've tried it. Would really like to get
this library...
Ken Klingman
Ken Klingman
Re: failure installing library
One other note. I tried installing another of the libraries and got the same error, so it's likely something amiss with my system and not the specific library.
John Beck
Company Name: John Beck Woodworking
Post by John Beck »
Can anyone help? I have the same exact issue.
John Beck
Post by John Beck »
I just got this library to install. I'm not for sure what I did to make it work, but I first went through and removed a bunch of garbage from my laptop. I then ran windows update over and over until all updates were done. I then ran ccleaner, including the registry cleaning over and over until it could find nothing to fix. I then thought I would try to install the library again and it went right through it.
Ken Klingman
Wish that would have worked for me. I did the same, other than "removing a bunch of garbage", but including running windows update until clean and then running registry cleaning. Still failed.
Ken,
Try right clicking on the installer then choose "Run as Administrator"
Scott G Vaal
Post by Scott G Vaal »
Ken,
Please download and install this Microsoft Redistributable package and then try to run the install(s) again.
http://www.microsoft.com/en-us/download ... px?id=5638
Ken Klingman
Installing the Visual C++ redistributable package did the trick. I hate Windows!
But thanks a million for the tip. The library install went like a breeze.
Ken
Scott G Vaal
Ken Klingman wrote:Installing the Visual C++ redistributable package did the trick. I hate Windows!
Ken
Glad to hear and thanks for letting us know it resolved your issue.
