If we could move the pcs on the nests to rearrange things in case we have defects that need to be worked around. Or sometimes the nest comes up a little weird and it adds a sheet to stick a part on it that will clearly fit on another sheet.
I think you can add a sheet with a void to accomplish the first idea. Not sure how you would go about the second idea on the controller other than tweaking the settings until it comes out close enough.
