Question about KD Fasteners
Scott Marshburn
Post by Scott Marshburn »
I have ben doing some homework on kd fasteners our regular supplier sells Titus brand similar to Rafax(Halefe) but upon a closer look Titus sells a drop in and a side mount. I looked on Halefe's sight but there was no mention of side mount or drop in.My question is (1) what is the difference from a side mount and a drop in (2) what do you guys that use kd fasteners use for Lock dadoes drop in or side mount?
Company Name: Halls Edge Inc
Re: Question about KD Fasteners
Post by Josh Rayburn »
Scott,
The drop-in is what Hafele refers to as "with ridge" versus "without ridge". The ridge prevents you from inserting a fixed shelf in from the end, in other words, you have to drop the fixed shelf ONTO the rafix studs that are sticking out of the left / right ends. Hard to explain. Basically you have more flexibility without the ridge. If you wanted to use one in conjunction with the blind dado, i.e. the lock dado with RTA's, then you would need "without ridge".
Hope that helps -
Scott Marshburn
Thanks Josh That is just what I needed.
Scott Marshburn
I have another question about Hafele /Rafix 263.10.705 What bolt do you recommend for particleboard 19 to 20 mm thick.
FredHirsch
Post by FredHirsch »
Scott,
We use 15mm bolt 263.20.856 with Rafix They also make an 11mm, either will work with those fittings.
Fred
Fred Hirsch
Scott Marshburn
Thanks Fred
