Cabinet rotating problem
Post by Donald Thomson »
As I sit here writing this post, I am watching a cabinet rapidly spinning uncontrollably on my screen in the cabinet editor. I've had this happen before. :wall:
It seems if you start doing a rotate operation of the cabinet while the program is off in lala land thinking about doing something else, when the program comes back from dream land it remembers you were trying to rotate and starts spinning the cabinet uncontrollably. It appears the only way to stop it is to use Windows Task Manager to end eCabs as it will not respond to any mouse or keyboard input.
It's a good thing I save after every edit operation otherwise I'd loose a lot of work because of this feature. :shock:
Anyone else see this behavior?
Scott Marshburn
Re: Cabinet rotating problem
Post by Scott Marshburn »
If you have not done so go to settings and preferences and make sure that enable cabinet auto spin is not checked
Thanks Scott!!!!
This program has so many features and options, it's hard to remember them all.
