build 10 upgrade
Mike Mahoney
- Company Name: MahoneyWoodcraft
build 10 upgrade
I am a small shop and use the software sporadically. I recently tried to down load the latest upgrade and cannot get the upgrade to work at all. I have went to the site, and downloaded. It goes through the process and says the install is complete, but when I try to open it, it tries to re-install again. I have attempted it many times but it simply won't install. Any suggestions?
Re: build 10 upgrade
Best method for us is to download the update to the computer and then make absolutely certain that you run as administrator.
Mike Mahoney
I tried running as administrator and it did not work. I noticed the shortcut icon on my desktop for e cabinet 6 has a shield on it, the same as the install shield. that never used to be there before i tried to do the build 10 update. If I try opening it up from the "programs" folder, it still brings me back to the install shield. It seems like the main program is gone. Something else that confuses me is when I go through the process it asks me to choose "repair" or "modify". I have tried both choices, but neither works.
