Display Objects
Display Objects
Post by Donald Thomson »
I am having a difficult time getting the display objects that are stored in the
C:\Users\Public\Documents\Thermwood\eCabinet Systems\Assemblies\Standard
directory to show up.
I've installed eCabs on my laptop and copied all the directories and subdirectories from C:\Users\Public\Documents\Thermwood\eCabinet Systems\ on my main design machine to the same location on my laptop. Many of the things that show up on the main design machine are not showing up on the laptop.
Are there other locations where duplicates of these files are kept that also have to be copied from the main design machine to the laptop?
I am going through all this hassle because I have to visit a customer on 1/23/2014 with a big job of cabinetry and other things I've been working on and want to be able to just bring the job over from the main design computer to the laptop and have it work.
Thanks in advance.
Scott G Vaal
Re: Display Objects
Post by Scott G Vaal »
Donald,
Display objects should exist in your user data path\import folder with sub folders under it. It appears by your post that it would be at C:\Users\Public\Documents\Thermwood\eCabinet Systems\import. Are the operating systems the same on each PC? You can verify the user data path field in your Settings/Preferences dialog.
